Tinster said:
What does it usually mean when you hear kind of a dull bang noise, the cars loses power and whitish/grey/black smoke
billows out the exhaust pipe? Just jurious. Blown head gasket?
Best regards,
dale(Tinster)
Head gaskets don't normally make noise when they give out. If this was definitely an immediate effect, I would suspect a rod thrown into the block cracking both a water jacket and allowing crankcase oil into the exhaust. If there's antifreeze in the crankcase, that'd be a dead giveaway.
I think we're all assuming this is a lbc with a manual transmission. Automatic transmission fluid will also give a white/grey smoke if it's finding it's way into the combustion chamber or directly into the exhaust. I've had a transmission fail in exactly this same way (1987 Ford Tempo company car), sound effects and all. The only difference is that it was less than a 1/4 mile before I lost all forward gears and I then lost reverse the first time I used it (to get the car off the road).
If you're losing power it's likely an engine failure. Check the oil and each spark plug and that should tell the tale.
Good luck!
