Just checking about spark plugs.
KindredSpirit
I've only recently got my Mark 1 BT7 Healey.
Maybe someone could advise me about spark plugs.
The original recommended ones were Champion UN 12Y. These are not made anymore.
The ones that have been recommended as a replacement are N 12Y; although when I went to the motor factors today, he said they had been replaced by N 12YC.
The ones that are at present in the car are N9 YC.
Which plugs do you think are the correct ones? N9s or N 12s? Or does it make that much difference?
Dave Russell
Yoda - R.I.P
The N9 is one heat range colder than the N12. If you are doing spirited driving & the present N9 plugs do not foul, it's probably a good replacement.
The NGK equivalent to N12 would be BP5. Equivalent to N9 would be BP6.
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
T General MG Checking tiers tread MG 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
K TR2/3/3A Checking steering box End Play? Triumph 5
B TR2/3/3A Checking oil in rear axle Triumph 2
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
E TR4/4A Checking a generator Triumph 12
5 Checking The Spedo Spridgets 11
PSJ Checking for interest - meeting of NW Organization of Spridget Handymen In Transit Spridgets 6
vette Checking RPMs Austin Healey 14
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
A TR2/3/3A checking axle float triumph tr3a Triumph 10
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
RickAnderson Checking an Engine Not in the Car? MG 2
M Checking rear break drums and pads Triumph 7
T Checking OD function w/out solenoid handy? Triumph 4
P Checking oil levels Triumph 6
drooartz Checking transmission/OD levels MG 14
N Checking a rebuilt engine Austin Healey 15
T Anyone interested in checking out a BN2 in NM? Austin Healey 14
M Newbie: Just Checking In MG 7
P CHECKING DIZZY CAP Spridgets 10
Gundy Checking B's tranny oil MG 26
T Checking for front suspension wear Spridgets 4
6 Checking out lever arm shocks Austin Healey 3
drooartz Checking a ribcase transmission Spridgets 2
2wrench Checking the thrust washers.....Dale? Triumph 3
vping Checking an axle ratio MG 2
Hap Waldrop Plastigauging for checking crankshaft clearences Spridgets 7
S TR2/3/3A door strap checking tr3 Triumph 8
M Another New Member - Just checking things out MG 9
G Checking & filling shock absorber fluid Spridgets 9
wkilleffer Checking distributor shaft wobble MG 37
N MGB Checking out MGB's Betwix Here and There MG 3
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
M Checking a temp guage Triumph 2
aeronca65t Checking Pertronix Unit Restoration & Tools 1
S Paint Checking on the Hood Austin Healey 4
G Checking leak in used radiator Restoration & Tools 3
TNMGB Checking/adding gearbox oil?? MG 34
D Checking Tranny Fluid Level Spridgets 5
N MGB 1978 MGB Coolant Level Checking MG 3
B MGB Another new owner of an MGB checking in MG 9
Andy Blackley Checking my 74B MG 2
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
