I just hauled in my new project.. 1951 MG TD .. supposedly has a new gold seal engine but the engine hasn't been started in years. After removing the head, my pistons are stamped +.040 on top. Does this mean it is bored out that much? My engine is painted gold on the valve cover and tappet cover. The engine appears to be extremely clean inside. The cylinder walls that are visible appear perfect. This is my first MG TD. Pressing the clutch doesn't disengage the transmission at all. Could the clutch/transmission be the reason the engine will not turn?
Thanks. /ubbthreads/images/graemlins/cheers.gif
Hi Guest!
