MCNX_BFF
ObiRichKanobi said:Should be a relatively easy job (if there is such a thing).
Well, Guys, it seems it won't be so easy. Apparently, I was not born under a lucky star. Earlier in the week as I eagerly anticipated starting on my boot project, I found rust behind the remnants of the bulkhead mat. Some of the black paint back there has flaked off and other parts are bubbled and lifted. The vast majority of the paint, however, appears to be well adhered. In the morning I will be removing the paint and as much of the corrosion as possible--it is my greatest desire to get rid of ALL of it! Hopefully, the rust is fairly superficial and not widespread under the cover of the paint. Assuming the rust isn't severe, what process and products do you recommend? Any and all ideas/suggestions are greatly appreciated. Thanks bunches! --Monica
