Jet-Hot headers came today!
drooartz
I got my headers back from Jet-Hot today. They do look purdy!
This package marks a real milestone in my refurbishment of the Tunebug. The headers were the last item I had sent out for work. I should now have all the parts I need on hand to finish up. It's all on me now! :smile:
I do figure I'll wind up with at least one more parts order for a few little things I'm probably missing, but the headers were the last big item on my list.
Plan is to have the engine in by the end of May, with the car back on the road in late June. Here we go!
John Moore
NICE!!! I jet coated my B headers and intake. They have held up great over the past three years. And even after a drive you can almost touch them with your finger. Good stuff, I'm sure you'll be pleased.
Go man go! I'm enjoying your progress. I got my MGB Supercharger buttoned up tonight. AMAZING! Soon I want to start on the bugeye again.
John! Stop playing with the MGB and show the Bug some love. :wink:
Brosky
I am very happy with my Jet Hot coated headers. And john is correct, they are a LOT cooler, but give them a few minutes before touching.
John Moore
Will do! Now that I got it installed, I'm fired up to get some work done on the bug!
G I called Jet Hot about my peeling SS headers... Triumph 20
G Jet Hot coating peeling off my headers........... Triumph 9
N Jet Hot??? Spridgets 13
R Jet Hot Coatings TVR 6
drooartz Jet Hot header coating questions Spridgets 13
Lin Jet Hot ceramic exhaust coating Austin Healey 13
Raymond Jet Hot? MG 13
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
torque-drive MGB SU HS4 jet height adjustments MG 6
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
K TR2/3/3A Unmarked SU jet needles? Triumph 3
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
S TR2/3/3A polish the jet Triumph 1
steveg HD series Jet Centering - a Caution Austin Healey 19
F TR2/3/3A Centering The Jet Triumph 14
T TR2/3/3A H6 jet bearing seals Triumph 3
H BJ8 jet drop measurement Austin Healey 8
BillyB62 TR2/3/3A Carb Jet Triumph 8
M TR2/3/3A H6 Jet assembly leaks after rebuild Triumph 6
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
M TR2/3/3A Forward Carb Jet Lever Bent Triumph 12
TomMull TR2/3/3A Wrong SU jet? Triumph 0
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
sim HUS 2 main jet adjustment Spridgets 40
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
K TR2/3/3A SU carb...after jet centered...jet lever hesitation. Triumph 3
T T-Series Need new jet levers MG 3
D Jet seals Triumph 2
K SU's again...Jet centering? Triumph 7
J Getting HS2 carb jet out Spridgets 11
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
Bremer Jet needle removal Triumph 7
jdubois What the heck is this jet needle? Triumph 8
K TR2/3/3A TR3 SU H6 Jet[Gland Packing] Rubber O RING Size? Triumph 3
K TR2/3/3A TR3A SU Jet marking .100 ? Triumph 6
G Who sells jet-to-bowl line? Spridgets 6
Nelson SU jet centering Spridgets 11
G Fuel hose replacement from bowl to jet Spridgets 4
doughairfield Jet Assembly sticking Triumph 6
H HS6 JET identification Triumph 2
B SU Jet ID's Spridgets 5
JPSmit carb jet question Spridgets 3
