Rhodyspit75
> Jay Leno Seriously Burned In Gasoline Fire <. It appears that Jay Leno was burned while working on one of his cars.
Saw that too. Thank godness he had a good friend near by who was able to jump into action to save him.read somewhere today that he may need skin grafts
Mike - I've been doing the "stick wiggle test" since I was in high school, to make sure I could ignore the clutch when starting the engine.
Yep, same reason. Plus while there is additional wear on the starter replacing it a bit early is much less expensive that premature clutch wear forcing a new one. Unfortunately the Toyota has a switch of some sort requiring the clutch to be depressed, both to start and to release the parking brake. Made for those without the proper habits...Mike - I've been doing the "stick wiggle test" since I was in high school, to make sure I could ignore the clutch when starting the engine.
Too many people back then would punch their foot down on the clutch, then start the engine, regardless of what gear it was (or wasn't) in. Not a good idea!
Mike said:Made for those without the proper habits...
