Finally got the front brakes sorted and then started the car for first time in 2 weeks and it seemed to be missing on one of the cylinders. I disconnected one plug wire at a time till there was no difference in the engine speed, problem was it seems to be on 3 cylinders. Counting from the front of the car it is 4,5,& 6.Checked compression,OK, loosed the connection between carbs and both seemed to operate ok. Should I maybe be looking at the ignition also even though it seems to have a good spark. I only changed the plugs when we got it running a month ago, filed the points as they looked new. The car also pings heavily upon acceleration so I'll be checking the Timing next but 2 weeks ago it ran beatifully. I'm a little perplexed. Any help appreciated, Charlie
