nevets
currently my Healey (BN6) is up on jack stands positioned under the two main frame members, 2 at the front and 2 at the back. Seems quite stable. I recently read in Norman Nock's tech tips that the stands should be positioned mid-way under the rear leaf springs and under the front spring plates. Is this the best way, and am I causing any damage by leaving the jack stands supporting the car under the frame? Also, if the stands are under the front spring plates, it will be impossible to remove the front springs. Any comments would be appreciated. thanks
