J-H no longer needs a push!
Ray Brandes
After months of work, our project moves under its own power. Charlie drove the two miles from one shop to another where we will start finishing it out.
When we first pulled the exhaust system, it was full of some thin oil like transmission fluid. The car doesn't smoke until it gets hot. We hope that the smoke is residual oil cooking off from the muffler!
https://www.youtube.com/watch?v=YdKVRSjT0z8
Thanks for all the help we found here!
Regards, Ray
NutmegCT
Hey - congratulations on the victories. Looks like one happy guy at the wheel there.
Interesting about the liquid in the exhaust system. Any idea what it is?
Tom M.
R
Ray Brandes
Tom M.
The car was sitting and we can only guess that some kind of light oil like trans fluid was put in through the spark plug holes in some attempt of rust proofing. The exhaust was welded from the headers to the tips and we had to cut it just forward of the "Y" in order to get the engine out as the steering column went between the banks. When we cut the pipes a great quantity of fluid poured out. I suspect the muffler packing is still saturated.
Regards, Ray
Bayless
Does look like one happy bloke. Congratulations on the 2 mile run.
Deleted member 8987
If the person who put the car up was extremely conscientious, pulling the plugs, running oil down the holes and hand cranking the engine a couple of turns periodically is good.
If they did that every six months for several years, then you get oil in the exhaust and muffler.
Neighbor did a 24-year restoration on a 1941 Lincoln Continental V-12, and every six months, a quart of 30WT down the twelve holes.
After 20 years, he decided we should probably see if it would start.
Ran it for 10 minutes, shut down, slammed the garage door down, and wait for the fire trucks to quit cruising the street. Seriously.
If he could have run it 2-3 miles, it would have stopped smoking (and a year later when we did, it did).
Had a drip pan under the muffler. Oil running out the seams.
Once you get it all up to temperature, should burn the oil off.
Deleted member 8987
Maybe oil from the carb dashpots?
Yeah, has to be it. Take the tops off, pour a couple of quarts down the carb, enough to coat the exhaust system to make it smoke.
Probably easier than jacking the car way up on the side to pour oil directly into the carb throat.
steveg Nisonger no longer in service business Austin Healey 12
K TR2/3/3A Longer wheel studs? Triumph 5
TomChar General TR LBC's no longer in their prime... Triumph 14
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
DrEntropy Can't put it off any longer. MG 10
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
Ed_K Castrol Syntec 20w-50 no longer available ? Austin Healey 21
K TR4/4A Longer TR4A intake manifold on a 3...... Triumph 5
T longer wheel studs need help finding Triumph 11
B I'm no longer safe! Spridgets 23
S This won't last much longer! Jaguar 4
AUSMHLY Longer grease fittings Austin Healey 8
zekjet TR6 Longer Front Wheel Studs for a TR6? Triumph 3
milemarker60 Looking for longer studs? Here's my research Triumph 2
A Its starrting to stay light out a little longer. Spridgets 4
catfood TVR No longer under British ownership... Other British Cars 9
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
AngliaGT My '95 Dodge Dakota Needs New Shocks Other Cars 4
mailbox For Sale TR 7 needs to go, either in parts or as a whole Triumph Classifieds 0
Popeye Post-War Other Mayflower for sale...needs full restoration Triumph 0
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
L Spitfire Newbie amateur mechanic needs help w/California smog equipment Triumph 6
H Restoration project, needs work Austin Healey 16
T Recently acquired BJ8 needs life Austin Healey 5
1 TR6 Tr6 needs choke to run good Triumph 11
mailbox General MG In case anyone needs a project or parts MG 0
S Someone needs to salvage this Spridgets 12
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
W Somebody needs to jump om this... Spridgets 2
judow Agatha needs a bandage... Austin Healey 5
B MGB Great success with spare parts for anyone who needs them, not for sale but for free.. MG 2
PatGalvin TR2/3/3A TR3 PS Quarter Panel Dog Leg needs a good home Triumph 2
drooartz Off Topic It really needs to stop snowing... MG 19
Rut Speedo/Tach questions and needs Spridgets 20
B New Guy needs to know... Triumph 19
H Conclave - Healey literature item needs? Austin Healey 0
M MGA New MGA Owner needs helps MG 5
W Somebody needs to gobble up this deal! Spridgets 17
J UBSCC Car show in Woodland CA needs race cars Racing 0
J West Coast British Car Show needs Triumphs !! Triumph 2
RickB SWA formerly RB Midget needs rear fender flaring Spridgets 60
M Triumph guy needs Austin Healey part information Austin Healey 7
lbc_newbie MGA Someone needs to get this, fast... MGA $1500 in SC MG 4
W Grocery getter needs repair Other Cars 1
toysrrus "FISH CARBURETORS": Who needs a pair? Racing 3
drooartz It's true: the Tunebug needs a new home Spridgets 27
F Who needs a Spring Compressor... Spridgets 12
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
