1979 Midget 1500.
Problem: At temps above 80 deg(F) after about 45 min. on the open road the engine begins to hesitate and even dies at stoplights. Starts up immediately at the turn of the key. It hesitates so much that I don,t think sometimes I'm going to make it home. Below 80 deg. I can drive it all day around town and it runs and idles perfect. I have a auto zone electric pump mounted back by the tank. I have 2 heat shield installed at the ZS carb. One that came with the car and another I designed from a thin aluminum pie plate with fibreglas insulation on top. Gas line is away from the engine and tacked to the inner fender well. I couldnt get the gas line any further from the engine and still have it under the hood. I'm not touching carb adjustments because like I said it runs perfect at lower temps. If gas is boiling in the carb. I cant do anything about that either. Ive taken all the precautions I can as far as shielding the carb. I've also removed the cat. converted which Iam sure got rid of gobs of heat. I'm out of ideas guys. Any suggestions ?
Thanks
Don
Thanks
Don
