rtylerwinslow
My car was running great. Better than it ever has. I thought I was ready for the track this Sat. and then it quit. At first it was a sputter that could be saved with a judicial "bliping" of throttle. Then it started happening more frequently. Then no amount of throttle would save it. Now, nothing. It won't start at all. I have replaced the ignition with a pertronix ignitor and coil and it has proven to work very well. I thought that since it sat for a while that it might be the gas or something clogging the fuel pickup in the tank. So I dropped the tank emptied the gas and put the tank back. Nothing. Next I changed the fuel filter. Nothing. Tonight I changed the fuel pump to no avil. I checked the body ground and the battey ground, both are fine. There is one thing I can think of. I replaced the fuel pump with the Moss Motors solid state pump. The pump that was on there before is the exact same one. I positioned the new pump exactly the same way to old one (that worked for years) was positioned. However, in the installation directions it says to install the pump at a 45 degree angle and my previous pump was at a much more shallow angle. I had my Weber carb rebuilt (completly) about 2000 miles ago, so I can't imagine it would be that. I'm really stumped. It was running so well after all my work for about a week. Now I am afraid I'll miss going to the track Sat. I would really appreciate any help you guys could offer.
Thanks in advance,
Tyler
Thanks in advance,
Tyler
