Griz
After 5 plus years of rebuild the BJ7 roared to life on Valentine's Day with 60psi oil pressure and no oil leaks, only a couple minor coolant leaks. That's the good news. However, old Griz needs some guidance from the wizards here. The carbs are gulping gas. I've checked the float bowls and they are working correctly and no gas is flowing out the overflows. I ran the jets up flush with the bridge in the throat of the carbs, double checked that the needles and jets are centered, and backed the jets off as directed in the adjustment instructions. Engine fires right up fine, then shortly begins to stumble especially when I work the throttle. When I shut it down gas flows out the inlet manifold drain tubes. I even ran the jets all the way up as far as they would go to lean out the mixture and I still had gas running out the manifold drains on shutdown.
Any advice??
Griz
Any advice??
Griz
