George Zeck
After ~ 18 mths -- my 1964 Sprite runs! The brakes actually lock up (when I want them to) and the engine runs / sounds pretty solid. Must have had 10 people yell what a nice car it was just "doing laps" around the block. Thanks for all who have helped me along the way.
Had difficulites once the car warmed up: My guess is after 3 to 4 miles -- I pulled over to check the oil and the level was OK (although had a drop or two just from the brief 2 min stop) -- I noticed "smoke" coming from where I fill the oil into the engine. This was definately smoke vs. steam.
I also noticed that the oil pressure gauge went from 60 lbs to 20 lbs during my drive (once seeing the smoke -- I eased it back home). also -- the water temp went up to 230 degrees (as I was pulling into the garage). I did have to add coolant (I wrongly thought I checked -- I was so giddy to actually take a drive).
Are these ranges (Oil Pressure & Water Temp) normal ?? I pulled the oil cap to let the smoke out / engine to cool once back in my garage and smoke came out for 5+ minutes. I'm sure oil will burn a bit -- but this sure seemed excessive.
I did check Oil again and level was OK. Let car cool. Added coolant (50/50) and took for another drive -- same reults. I just didn't drive as long and water temp appeared to level out at 190 ish.
I did change oil (10W30) but NOT the filter -- will do that next and check the "oil overflow tube" for blockage (tube on RH side of engine going north/south similar to coolant overflow tube). Probably replace thermostat / hoses for safety as well. Not sure if that will help the smoke issue -- but will make me feel better.
Is this normal ??? Any recommendations I shold look at. The car sat unused for 18 yrs so I expect to run into "issues" -- just wasn't expecting this. /ubbthreads/images/graemlins/patriot.gif
Hi Guest!
