blkcorvair
Well I finished the complete wiring harness and dash yesterday. Only one wire that I questionably don't know how I hooked it up wrong but none the less, all the bells and whistles are working. So I put my elec. fuel pump in tonight fabricated some cables and brackets for the new su carb and topped everything off. And whala! It started. Turns out I was flooding it because I had the overflow and feed hos crossed, but after working that out I doens't stay running. Pops stall, stumbles stalls. Fuel is definatally getting to the carb. But I must say I have not touched an SU since I worked on my Datsun when I was 15. So it is a bit new too me. Dont know if I may be doing some thing wrong. Maybe fuel pressure, or that adjustment for the needle seat. (Which I have set at two turns out.) I assumed plu the balance tube (From the original 2 carb setup and I rebuilt the carb.) The timing ought to be fine at least to get it running as it ran with the weber before I yanked the engine. Never fooled with that. Any suggestions. Here's some pics!
