Bill Tubbs
This morning was the moment of truth. I rechecked all the connections on the carb and manifold, reconnected the battery, and hit the ignition.
Within about 3 turns, the engine fired up and ran smoothly for about 30 seconds... then gradually died.
I couldn't get it restarted although it was firing intermittently. I checked under the hood and discovered a little gasoline dripping on the exhaust manifold, telling me that there's a loose connection on the carb somewhere, or the carb has a dried out gasket somewhere and I need to rebuild it (dang). Since this carburetor has been sitting idle in a box for several years, I'm assuming the latter. Does this sound right?
I'm going to remove it this weekend or during the week and see if it's obvious. Is it difficult to rebuild a CD-150? A couple of LBC specialists I've called in the recent past indicated they charge at least a couple hundred to do this. I'm willing to give it a try for that amount of money.
What's the consensus??
Bill
Bill
