racingenglishcars
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
Not wideband.
You need wideband.
Try a "do it yourself wide band" or diy-wb, using a honda sensor.
https://www.aces.edu/~parmega/efi/temp/wb/guide.html
https://www.diy-wb.com/
BTW air:fuel ratio 13:1 is also many times referred to by its dimensionless value lambda 13/14.7 = 0.88 while stoichiometric is lambda 1.0. The guage can be calibrated as such.
Not wideband.
You need wideband.
