I have installed a new Sony radio/CD/Ipod in my 3000 Mk 1 BT7. The car is positively grounded and I have installed the radio using a voltage inverter using the same connections that were used on the older (late 80s) radio that I removed in working order. The insallation works pretty well but....
1 These modern radios have memories with pre-set stations, since I've hooked it up through the ingnition, I lose all the pre-sets and clock time each time I turn the car off. I suppose I could run a dedicated line from the battery to the voltage inverter, bypassing the cutoff switch, however I'm concerned that this may drain the battery. I can live with losing the pre-sets etc but any suggestions would be welcome.
2 The more annoying issue is that the radio seems to switch off/stop working sometimes, particularly when I step on the break (but not always). It does start back up again on the same station and still remembers the pre-set stations, so it's not as if the power has been lost to a degree that would lose the pre-sets. I've checked all the connections which seem good and the wires don't run close to the brake peddle. The radio is well grounded and I've put a voltmeter across the terminals which shows good voltage, but it does seem to dip momentarily on occassion. One thing I thought of is that I have a rubber cover on the accelerator but not the brake peddle. Any ideas what's going on?
Many thanks for any help you can give, Andrew
