After purchasing my first Sprite in June (its a '66 body with a 1275), I finally got it back from the shop (new clutch slave and master cylindar) after what seemed like a year. I took it out for the first time today, and boy is it fun to drive! It doesn't like to start unless it is hooked up to a charger, for maybe 1 minute. I am assuming I just need a new battery, right? Also, when it is in gear, it makes a sort of grinding noise like it is not fully in gear, even though it accelerates fine. Maybe it is just the noise of a 45 year old car? I have a whole host of issues that I hope to tackle this winter when I have more free time. What are the "easiest" of the following issues: Tach doesn't work, headlamps don't work, horn was disengaged because it went off whenever I would turn the wheel, turn signal lever is loose inside its housing. If you cannot tell, I am a COMPLETE NOVICE when it comes to cars. I am hoping to learn about the engine through reading the manuals, because honestly, I do not know what to look for as far as the sounds, smells, etc. Any insight is appreciated. I am really excited I decided to buy my mid-life crisis car at 33.
