cdsmith
I took the little car out for a spin a while ago and after I got back I discovered the left front brake was dragging. Upon closer inspection it turns out the trailing wheel cylinder was frozen - this explains the hard pedal.
Yesterday was the first chance I had to take a closer look, so I removed the brake shoes and was in the process of removing the trailing wheel cylinder and I heard a thump - the leading wheel cylinders piston dropped out! Just dropped out!
As I said... Is that suppose to happen? What holds the piston in?
Now I have to decide - do I fix what I have now or do I consider disk-brake conversion... Decisions... Decisions...
cd
cd
Sometimes I will leash them so this doesn't happen while changing components.
