Is this right?
I'm back with the car tomorrow. I'll have them after lunch. Sorry for the delay.
Well, I decided to test the valve timing per the manual.
So I....
1) opened the valve clearance on 11 & 12 to exactly 120 thou while on the base circle of the cam.
2) Set the engine to exactly TDC compression stroke
3) Checked the 11 & 12 valve clearance and found 12 at 25 thou and 11 (inlet)at partial valve spring compression
4) they're supposed to be equal Oh Oh!
5) drained the antifreeze and tore the the front end apart to reach the timing chain
6) set the cam to get 11 & 12 equal (18thou) while maintaining TDC
7) Had to move it 2 teeth over to get it correct
8) now partially reassembled, finish tomorrow
fingers crossed that this should improve the idle/runon situation, oh and get the vacuum up where it's supposed to be.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]6) set the cam to get 11 & 12 equal (18thou) while maintaining TDC[/QUOTE]
Graham,
According to the TH5 printed installation sheet the camshaft checking clearance is .010" for both intake and exhaust, over the 290 duration.
However, my final valve clearance adjustments are set at .014" for the intake and .018" for the exhaust. That was a handwritten note on my spec sheet and I confirmed that with Greg at BPNW prior to the installation.
Yes Paul you are correct, 14in/18out thou are the correct running clearances per the sheet I got with the cam also. The 18 thou I mentioned above is to set the lobes on the number 11 & 12 valves evenly straddling, thereby ensuring that at TDC those rear lobes are exactly evenly distributed about the TDC centreline and thus ensuring the valves are timed correctly. The 18 thou just happens to be the even clearance (on this cam) with a base circle clearance pre-set at 120 thou.
I think that's clear, at least it is to me!
Graham,
My vacuum reading is steady between 14"-15" at 950 RPM. I hope that resetting the gear position clears yours up.
Thanks Paul.
I fired it up briefly yesterday without the rad and a bunch of other stuff installed just to see if it would run; it ran very smoothly for the 30 seconds before I shut it off; so I think I got it right this time.
It's remarkable how quickly one can tear down and reassemble something when you've just done that job a week earlier; of course I know which tools are needed and there's no rusted bolts 2nd time around!
I'll let you know what the vacuum readings are when I get it fully back together.
SUCCESS!
All back together now and it runs and idles like a champ without all the shake rattle and roll. No run on either.
So that was the problem, about 1-1/2 teeth off (advanced) on the cam sprocket. Could have sworn I had it right when I first put it together but I didn't.
Now I just need to get a few more miles on it so I can open it up past 3K rpm.
Oh and vacuum is steady at 12" at idle
Good job! Those first 500 miles are like the months before you turn 16 or 21. They seem to take forever......
