Is there a way to take apart and clean/repair the inside of a TR3A headlight dimmer switch? Mine was very rusty and would not move. I sand blasted the out side and put a bunch of PB Blaster down in the push button. If I work and work the push button, at times I get continuity between the center connector (the one that gets power from the headlight switch) and the connectors on each side at separate times. So it would appear that the switch may be good, but just mucky inside and not allowing good movement inside. I have no idea what the inside of one looks like. It would appear that I could drill out the two "rivets" that hold it together by drilling from the front of the switch. But not sure what I'd do once I got inside. Has anyone tried to take one apart and clean up the inside? Thanks!
Regards,
Regards,
