TR2/3/3A Is there a way to get more clearance between tires and back fender on TR3A?
TuffTR250
Is there a way to adjust (probably lower it closer to the frame) the ride position of the back axle relative to the frame to give greater clearance between the tires and the edge of the back fender?
I am running 205/50-15 Hoosier tires with TR6 wheels on my "driver" TR3A. They are very close to the outer edge of the back fenders and I'm concerned that when I go over a large bump the tire may rub against the edge of the fender. I'm not positive, but looking at the tires it appears that they may have rubbed a couple of times. I really want to keep using the Hoosiers, so I'm looking for a "fix" that would allow me to continue to use them so I don't have to buy narrower tires for my TR6 wheels. I have attached a couple of pictures showing how close the fender is to the tire. Thanks for any ideas!
Regards,
TR3driver
Great Pumpkin - R.I.P
Try reshaping the lip of the fender just a bit. I was able to pull mine out by 3/16" or so just with my hands; you could probably get a bit more using a piece of wood without doing any serious damage.
No easy way to increase the ride height, except new springs of course. Since the springs run under the axle, the usual spacers will decrease rather than increase. And turning the shackles over would be way too much. You might be able to get away with making some shackles that are about 1/2" shorter, but I'm not certain that would leave enough travel. Another approach might be to add shims between the body & frame, but that will cause other problems (like the tubes for the rear bumper mounts won't line up).
I've been running 205/55 on TR6 wheels for a long time now. They do rub a bit on my car (after spreading the fenders as above), the sidewall gets polished up, but it doesn't seem to hurt the tires. If you look close at this photo, you can see how the tire surface is shiny, and the fenders bulge just a bit.
T
TuffTR250
My rear shocks could very likely be weak. They look like they could be originals. I did check the fluid a couple of years ago when I got the car and I could see fluid in them when I removed the filler plug. Would rebuilt rear shock increase the rear ride height?
Regards,
TR3driver
I agree. Besides, if you drive at all, the rear axle is going to work throughout it's entire range, from hitting the bump strap to hitting the frame. Mine also deflects sideways in a hard corner.
T
TuffTR250
I have a question about the shackles. When the car is setting after driving the top of the shackles are pointing toward the back of the car (see first picture below). When I jack the car up under the frame, the shackles are in a straight up and down position (see second picture below). Am I correct to assume that the weight of the car makes the shackles lean back,and then when I jack it up the weight of the axle and wheels push the springs down and make the shackles go straight up and down. Is this the way they are designed to work?
Regards,
TR3driver
The eye-to-eye length of the spring changes as the spring bends. The shackle takes up the difference in length (since the attachment points on the frame obviously don't move).
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
