I installed new Brake and Clutch Master Cylinders on my TR3A along with all new wheel cylinders/rubbers and pipes. I used Silicon Brake fluid from Moss and Master Cylinders from TRF. Within a couple of weeks both Master Cylinders are leaking out the front. I know that the Master Cylinders from TRF are specifically labeled that the use of Silicon Brake fluid invalidates the warranty. However, I have seen the threads on this forum where people have used silicon fluid in their TR3 with good results. I called both TRF and BPNW and both stated that they did not know of any place selling TR3 Master Cylinders that were designed to use silicon fluid.
Does any one know of a source of either Master Cylinders or Master Cylinder rebuild kits that are safe to use with Dot 5 silicon brake fluid?
p.s. I do not want to use Dot 3 LMA brake fluid!!
Thanks and Regards,
Thanks and Regards,
