1976 MG Midget with the 1500cc engine. PROBLEM: Burns oil, looses oil pressure, starts to clatter and dies after about 15 miles of driving.
I have 150 compression on all cylinders. Cold start I have 70psi oil pressure and NO noises. It was pushing oil out the dip stick tube so I disconnected the hose from the valve cover to the charcoal canister thinking too much crank case pressure, no more pushing oil. I drive it about 15-20 miles, engine temp 120 degrees and stays there but it starts to loose oil pressure, sprays oil out of every place possible starts to clatter a bit and dies. Let it sit 10 minutes or so and it starts right up, oil pressure back to 30-40psi and no noises. I have a Stromberg Carb, vented oil cap, electric fuel pump with the mechanical still in place but bypassed. I'm running 10W30 oil with a AC PF53 oil filter. Is my engine junk or am I missing something? PCV? Heavier oil weight? Different oil filter? I don't want to rebuild it if I don't have to. My engine guy say rebuild but I'm thinking maybe not. Too much crankcase pressure? Help please?
