regularman
Hi guys. I haven't been on here for a while dealing with all that bothersome non spridget stuff called life. Anyways, its cold weather here and I thought I might attempt to dig into my weird overheating problem on the midget. After the car has been sitting and not run for 3 weeks, when I remove the radiator plug there is air pressure still in there. In most normal systems, if the water got hot then it would force it into the overflow and then out the pressure cap and when it cooled it would draw back in from that tank and refill the sytem and the radiator would never get low. With a full radiator of water the car runs nice and cool, but once it gets heated up one time, like in a hard pull up a hill, it starts to run hotter and hotter until it would boil if not shut off. I put a new water pump on it when I went through the engine, the head gasket is new and the engine block and head were in great shape when I checked it. The radiator is new also and the hoses. I even added an extra heater core and plumbed it to the back for extra cooling capacity, so I should have plenty of radiator. I can have the heater on as well and by the time I get to the top of a good mountain climb, he is running hot. New 160 degree thermostat as well and new radiator cap. This thing has me flustered. It acts like no other overheat problem I have ever had before. I wonder if I am just not getting enough circulation and the water is boiling somewhere in the head or something. I need a way to check flow and I need to know about how much it should be.
