kurts100
Driving home from a car show in my 100-4 and the car started running like it was only on 2 or 3 cylinders. Barely could make it up hills. Stopped and changed spark plugs, filled the gas tank with premium and started off again. Nothing changed. Still ran horibly, however at an idle it ran fine. I nursed it along and then thought to pull out the choke. Ran much better. Not 100% but got me home using full choke. I've always had problems with this new fuel pump (lucas w/ points). Would stop for no reason and I'd beat behind my seat and it would start up again. I've cleaned the points and actually put very small amount of clock oil on some of the pivot points of the point mechanism. That has helped with it just stopping on me.
I'm thinking that the pump isn't pumping the proper pressure, since it runs at idle but not well when you give it gas. Since it ran much better on choke thought it might be starved of fuel without choke because of a bad fuel pump.
Any thoughts. I'm thinking about switching fuel pumps to the electric solid state one that Moss sells. I bet this one I have now doesn't have 2000 miles on it. Thanks! Kurt
