Is it a bad idea to buy a higher pressure radiator cap?
Hi All
Just noticed this interesting thread and have a related question please. I have just managed to get hold of an NOS 180 deg sleeved thermostat and intend to fit it. I noticed that Randys photos show two gaskets. I have the one with the two stud holes but what is the other thin ring? Is it required and available?
Thanks Steve
I'm using the Robertshaw 180 thermostat with sleeve. See this older thread:
https://www.britishcarforum.com/bcf/showthread.php?101510-Robertshaw-sleeved-thermostat
You can do this TOO!.
ADD A:
Sleeve from Moss.
Hi All
Thanks Steve
I think you're referring to #47 on this page: https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28859&SortOrder=380
It's a thin paper gasket; I usually install it but I think they eventually dissolve. All it does, I think, is prevent a little leakage around the periphery of the thermostat.
I'm using a regular thermostat with one of the Moss sleeves. Works fine and costs less.
I was using one of these cut away except for covering the bypass port. This in combination with the Moss 180 fail-open t-stat. Looks a little constricted compared to the Robertshaw:
My wife and I drove our 58 100-6 from Denver, CO to Iowa for my 10 year high school reunion in 1985. It was 100^ on the 4th of July. Even at freeway speeds, the engine was hot and the fuel pump was continually running. But, ya know what - it worked. Still running today ( although ) I am in the middle of a complete resto focused on body and chassis. Our feet were burning, and I said "that's the way these cars run". We put ice under our hats and in our shirts ( no top,on car). It was a hoot of a trip.
Our feet were burning, and I said "that's the way these cars run". Yeah:>
That was 54 years ago we have found out how to cool em down a bit now:applause:
