Is an epoxy patch ok on a fuel tank?
I would look into a welded repair as well. If it's a stress crack, it could be repaired fairly easily. If it's due to corrosion, you're probably looking at replacing a larger section in order to avoid another repair later.
Im not having luck with my local radiator repair guys, so I may try the epoxy route and keep a close eye on it.
[ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif At least give it a try, if it doesn't work then take further action, but right now you've got nothing to lose. As I said before I used an epoxy patch on the B and it's been fine for 3 years! I've been keeping a close eye on it too. /ubbthreads/images/graemlins/cheers.gif
