Is 4K too much for an engine rebuild?
Miser
This machine shop is good, they rebuilt my MG engine and I've had no problems. They quoted me around 4K US for a rebuild. They said they would come to my house and pick up and return the motor which is nice because I don't have a truck. Is 4K too much?
DNK
That's lime saying is 200K to much for a house.
Not enough info
tdskip
As Don said, depends on what you need and what they'll do.
Maybe we can start here - why are you having it rebuilt?
PM me if it is a local Brit car specialist since chances are pretty good I know them.
My stage 1 engine build cost would be inline with TRF, and includes many goodies like ARP fastners, APT camshaft and lifters, vernier timing gear set, tri metal bearings and such, so I'd say $4K is fair for a professional who knows what he is doing, and uses good parts. In fact, it sounds just a little low to me.
hondo402000
you definately want a complete detailed list in writing of what they are going to do, including a list of parts they will replace, unless you are providing the parts, and sometimes if you provide the parts they will not warranty the rebuild. I would mostly be concerned about the lifters and cam they use or you purchase
and 4K sounds a tad low but then I probably went overboard on my rebuild, and believe me you can get to 15K in a hurry
Hondo
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]They quoted me around 4K US for a rebuild.[/QUOTE]
The key words here are "around $4K". That is as broad as it is long in the real world and it can go to $6K really quick, if you don't have an itemized list as Hal suggested.
For reference, look at my site and you will see about $6K including parts and all labor. For what I got, I believe that to be a very fair price for the quality of the work here in New England. It was two years ago this month that it was done, so it would be higher now.
AND......as you can see, every step was documented. No shortcuts and no compromises.
Thats another thing as well, where in the country you are, and I see you're in CA., so naturally labor cost will be more there than say where I'm at, in SC.
JImEgan
I paid about $6K last year parts and labor. Included balancing and cam bearings installed and Richard Good's roller rockers. Had Her Majesty's Service do the rebuild. But, as Eric at HMS said, overbuilt and understressed( my polar opposite )
Lewis_McDorman
Is 4K too much for them to do what?..."Everything"? I built my engine myself and I can't put a pricetag on the experience, because to me it was thoroughly enjoyable. The only labor I paid for was the machining. I'm not saying that building your own engine is for everyone but I thought it was great. Understand, I'm no expert. My TR engine was the first engine I ever rebuilt. Do yourself a favor: Take a good look at the guy who's going to rebuild your engine for you and ask yourself "Does he look like he's more intelligent than I am?" Do yourself a favor: invest in a shop manual (Bentley), a torque wrench, some beer and some Doritos and go for it.
Platinum
:lol:
But ya forgot to add: micrometers (and standards), pin-gauges, Plastigauge, MORE beer... :jester:
Jeremy said:
Originally Posted By: tdskip--But ours aren't Italian.
True, true. I think the last British motor I had rebuilt cost $2.5K, but that was a few years ago.
The 1750 in this Spider was a less-than $1.5K outlay... but I was the assembly labor, did the head work as well. The English mills come in about the same. :wink: :devilgrin:
That said, I think Hap is right about it seeming a bit low, actually. All depends on what constitutes a "rebuild" in the opinion of the shop. Really no way to tell 'til the thing is disassembled and inspected though.
jdubois
There's the real truth. You'll almost always find bill increasing surprises once you're in there...
billspit
I spent just over $600 for the machine work and parts for my Nissan Z-24 engine. Machine shop has a reputation as a "decent" shop. I did the reassembly. Unfortunately, the truck had sat for a few years and I eneded up having to replace a lot of the fuel injection and emissions stuff that drove the total cost up to probably $1600. Its been running fine for three years now.
hondo402000
and while you have the transmission out you might as well go thru it too 2500 but thats with an A type OD unit up rated cone clutch, new uprated layshaft and lay gear and thrust bearings plus all the stuff that gets replaced in a normal rebuild
Hondo
DrEntropy MGB Differential with too much lash MG 5
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull Air Compressors, how much is too much? Restoration & Tools 7
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
F Too much procrastination[maybe long winded] Austin Healey 9
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
CZ_Dave One is too much, a hundred isn't enough MG 4
Got_All_4 TR2/3/3A TR3 leans too much to the right Triumph 10
DNK Too Much Time. MG 0
RobT TR5/TR250 TR 250 Compression Ratio - is 10.4:1 too much? Triumph 9
6 too much oil pressure??? Triumph 25
smaceng Too much candy-What to do? Spridgets 26
P IS $500.00 Too Much? Triumph 15
lbc_newbie How much is too much? Spridgets 4
jlaird Too much Spridgets 5
Bob Claffie Too much fuel pressure Austin Healey 9
G Next time you think parts 4 the LBC cost too much Other Cars 4
Steve1970 TR6 TR6 -- clutch pedal has too much play Triumph 9
John Moore Am I Paying Too Much? Spridgets 14
D Too Much Excitement for One Day Triumph 11
guzzul Differential gear 'slop'....how much is too much? Triumph 9
WidespreadPanic Floorpan surface rust - how much is too much? Triumph 13
SCguy TR6 Too much time on my hands, TR6 pictures Triumph 6
Andy Blackley High Oil Pressure: Too much of a good thing? Triumph 11
Steve_S Too much truck? Other Cars 14
R Where to go to evaluate: too much rust to fix Austin Healey 10
Basil Twin Webers too much Triumph 15
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
