Keoke
Whenever I have seen a rotor fail, the engine just stops.
I will agree with that John.
I'm glad your found and fixed your problem, but I'm perplexed by the cause. Retarded timing would cause consistent poor running and performance, and probably worse mileage (timing advance at cruise is mostly for more efficient combustion, hence more power from a given amount of fuel, hence less fuel required), advanced timing could cause detonation ('pinging'), whether you hear it or not. Did you make any other change besides changing timing? It's conceivable just dis/reconnecting some wires removed some corrosion or caused a better connection to be made. Sounds unlikely, but I'd swear just washing my car makes it run better.
