Marksg11dna
I finally diagnosed and fixed for now a frustrating starting problem on my '76 TR6. Turned over nicely and there was a spark at the plugs and 5 volts at the coil + terminal. I rebuilt carbs, had the distributor rebuilt, timing, valves, etc where OK. FINALLY it came down to a faulty ballast wire. The wire was intermittently faulting therefor hard to diagnose. So, I replaced the ballast with a standard external ballast and the car started right up. But I was now getting 12 v to the coil. So I've bypassed the ballast all together with a wire joined at the ignition switch and changed to a non-ballast coil.
Two questions: 1) Will I need to go back to a ballast system when the weather cools (I won't run it in the winter in Chicago)? 2) There was a 2nd wire on the + side of the coil that was dragging down the voltage to about 2.5 volts. I clipped it and everything is still fine. What is that wire?
-Mark
-Mark
