Intermediate" MISS "on my 69 MGC roadster
I have a great running MGC at idle and on acceleration.The problem is that it has a nasty miss from 1500 rpm's up.It still has a good amount of power but if you listen to the engine running over 1500 rpm's it misses terribly.I have no vaccum leaks ,adjusted valves,new plugs,cap,wires,rotor,rebuilt carbs,pertronix ignition ,timing is ok and has good compression,It is most annoying pllllllllllease help.Any suggestions would be greatly appreciated.Thanks,Jeff
