MGC Intermediate" MISS "on my 69 MGC roadster
jeffreys
I have a great running MGC at idle and on acceleration.The problem is that it has a nasty miss from 1500 rpm's up.It still has a good amount of power but if you listen to the engine running over 1500 rpm's it misses terribly.I have no vaccum leaks ,adjusted valves,new plugs,cap,wires,rotor,rebuilt carbs,pertronix ignition ,timing is ok and has good compression,It is most annoying pllllllllllease help.Any suggestions would be greatly appreciated.Thanks,Jeff
Re: Intermediate" MISS "on my 69 MGC roadster
Which carbs? And is the dizzy advance working?
I put a timing light on the engine and increased the throttle and the timing did advance.I also put a vaccum on the distributor with a hand vaccum pump and the advance assembly moved (engine off).The carbs are the original SU's HS6.Which were just rebuilt by a major SU rebuilder.Thanks Jeff
But do you have vacuum at the hose connecting to advance mech while running? It takes a combination of both advances to have a smooth operation. You may have determinind only that the vacuum advance is working correct. The centrifugal adbvance is teh one most likely to freeze up or encounter broken springs, etc if vacuum system is otherwise fine.
have you looked at the plugs after running awhile? I had a miss in mid range - turned out I was running too rich and they were carboned up
If you are running "non-wire" wires, (carbon impregnated non metallic cores) with a dizzy cap that has the old style screw in connectors occasionally they will degrade at the connection point and arc causing a random miss. Bob
