69sprite
Pulled all the interior out of my car on Tuesday. I was not happy with the product I had used for sound deadening and heat deflection. It was a foil backed heavy felt product that was being sold 4-6 years ago. Either the way I had installed it or the Texas heat had done a number on it. Some of the felt had come unglued from the floor pan, some of the foil had come unglued from it's factory felt, and some of the carpeting was just sliding round on top of the foil. I was having to have something to weigh down the rear deck carpet to keep it from flying out on spirited drives and especially hated the dread 'bunch up' that happened in the driver's foot well. I was almost afraid that one would create a 'Prius pedal', as the bunch up could have jammed the accelerator pedal.
I am cleaning all the accumulated debris out of the tub and am going to put down Eastwood's version of Dynamat. When I put down the new carpet a in 2006/7, I had treated the entire area with rust converter, then painted it with a paint that was supposed to work with the converter. All of that seems to have worked well. There are a few places I need to go back over.
My question is, it there any special cleaner/treatment that I need to clean the surface of the tub with, before I start putting down the Eastwood material? I want it to adhere well, so I don't have the detachment issue happen again.
Thanks
Larry
Thanks
Larry
Hi Guest!
