interior lighting-guages
while my dash lights have that very romantic kinda dim lighting,i cant read the instruments at night.can i just change out the bulbs for brighter ones?or am i going to rewire the dash?anyone run into this problem,and yes keoke-the battery switch is on, the battery and generator,[dynamo] are fine,its my failing eyesight that needs the help,thanks all. /ubbthreads/images/graemlins/eek.gif
Good day Anthony. I replaced the gauge lights in my AH with Halogen bulbs from the LBCCO (Little British Car Company) they can be found on the Internet. I've found the Halogen lights to be quite bright, in fact so bright you can almost read by them.
Well A7777, I wasn"t gonna say nothin about them things. However, If the problem is your "Failing Eyesight" you might want to talk to Tahoe Healey, since that type problem is out side my scope. But I do have a cigar lighter recepticle installed in my dash which allows a reading lamp with a flexible support to be plugged in and it can be trained on the dash guages in a non interfering manner so I can read them at night if required. I also use it to read maps at night too when traveling on unfamiliar roads---Keoke /ubbthreads/images/graemlins/wink.gif
Keoke, You sure are getting a bad rap on this forum! Being a Luke Skywalker, you out to work some of your magic on these unappreciative healeyites!
May the force be with you!
Well BH, You know what they say: If you can't take the heat don't stand in the sunlight. Besides these guys are not so bad you should hear those buggers in the UK Wow!---Keoke /ubbthreads/images/graemlins/laugh.gif
OH im sorry BH, TH sent the bill to the wrong guy ill have him correct that. /ubbthreads/images/graemlins/angel.gif
thank you all,very helpful,and black healy its not that im unappreatiative of my friend keoke,quite the contrary its just that i knew upon reading my question, in less then a nanno second his brain would be flashing with 3-d full color images of the healey schimatic,i just wanted to slow him down a bit[if thats at all possible].when he puts in his two cents its worth a billion!its off for a cig lighter and holagen bulbs!thanks all.
Well A7777, if you see the light you won't need {Tahoe Healey} after all. Opps that just slipped out.---Keoke /ubbthreads/images/graemlins/grin.gif
