jlaird
Polished the carb needle rods and I mean hand polished with brass polish before I put things back together. They were really smooth and fitted the top brass centering part to perfection. I also soaked the cork O rings overnight in oil as someone suggested. All went together very smooth, carbs returned to closed position perfectly without fail and it has been 30 min or so with fuel in the system and running the elect pump from time to time.
NO FUEL LEAKS YET ANYWAY.
So the answer is polish the carb needle seats till they are really nice and smooth and fit the top brass centering piece just right. If you use cork O rings soak them overnight in oil.
Waiting for wife to depart the area before I roll her out and fire her up and see if I can get a decent idle and balance and such. Oh yea last nite I removed all the intake back to the manifold and used form a gasket when I put it back up. If I had a leak there I no longer do.
More later.
Jack
More later.
Jack
Hi Guest!
