TR4/4A Interesting Tranny problem
Got_All_4
Fixed a tranny for someone a couple of years ago and got a call from him saying that when the car is sitting still he can go through all the gears including reverse. But once the car is in motion going from 2nd to third is like hitting a brick wall. Tried to skip 3rd and go into 4th and the same thing. Also can't get into reverse from time to time. I suppose with the engine running and sitting still.
All the detente balls and springs were replaced. I polished the main shaft and bushings and everything slid very nicely He probably has a couple thousand miles on it. Did complain once that decelerating there was some noise. Told him to change the gear oil to Red Line GL4 but he used regular 90 weight he said it's better. Any ideas what could be going on here?
CJD
Sounds like an issue with the little lockout ball in the shifter cover, between the shift rods, that acts to prevent shifting into 2 gears at once. Maybe it is sticking so can't shuttle back and forth like it should?
DavidApp
The gear lever that came with my new OD transmission is difficult to move into some gears positions. Transmission is not n the car yet. I am not going to use this cap on my car.
I noticed that the inner cap is catching on the outer cover as you try to move into some gear positions. In the photo you can see the wear on the outer cover. Could this be the issue?
David
Got_All_4
Got_All_4
Had one guy that said the end play on the main shaft is too loose? Not sure how that would work. I don't think the shaft moves but the steel bushings/washers were measured and replaced.
LarryK
GL4 yes. His 90 wght is covering something if it is better. Might be a slider out of align.
CJD
End play would allow the shifter to move, but not fully engage the gear. So not likely your problem. Could be a jammed 3/4 slider...but that would be rare. My money is still in the top cover.
Got_All_4
Got_All_4
Just got a call from the guy. Took the detent out of 3/4 gear shaft and was deformed and believes it was jamming. Had him switch covers and all seems well now. However he got another problem where his oil pressure is staying at 60lb no matter what RPM.
TFB
My hot oil pressure is 50psi hot idle 800rpm,max 75 at speed.13k on rebuild.
Is 60 psi a problem?
Tom
Got_All_4
Got_All_4
He is concerned that something happened after he drove home in 2nd gear for 30 miles at 3k. I told him I've driven my TR3 for over 2 hours at 60 mph and 3200 rpms and never missed a beat. But his registered correctly at idle 20lb and driving at 60lb. He is going to change the oil and told him to add a pint of Marvel Mystery Oil and if anything is gummed up that might clear it up. Then if that doesn't work replace the oil pressure spring.
jvandyke interesting '62 with auto tranny Spridgets 11
JPSmit Interesting experience yesterday Restoration & Tools 2
JPSmit Interesting Hagerty Article Spridgets 12
AngliaGT Some Interesting Cars Other Cars 10
AngliaGT Interesting Article on the V12 Jaguar 0
Sherlock Another cruise night, more interesting British iron Spotted 2
AngliaGT A Few Interesting Vehicles Spotted 32
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
B After bead blasting the body I noticed some interesting things… Spridgets 2
JPSmit Interesting bit of trivia tonight Other British Cars 0
JPSmit Interesting back story Other British Cars 0
Healey Nut Interesting car for sale in the UK . Austin Healey 1
PAUL161 T-Series Interesting Speedometer Scenario MG 5
Healey Nut Interesting but expensive Austin Healey 3
JPSmit Interesting project - and a twist on the hardtop. Restoration & Tools 12
nevets Interesting article about BaT Austin Healey 1
nevets interesting article about converting classic cars to electric power Austin Healey 7
lbcspinners Interesting Jalopnik article on BEING TOUGH ON TODAY'S ROADS !! Austin Healey 7
HealeyRick MGA Interesting MGA Fastback MG 9
JPSmit Interesting video - cast bakelite knobs Restoration & Tools 2
S Well, this should be interesting..... Other Cars 9
AngliaGT A Few Interesting Cars Yesterday Spotted 0
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
CJD General Tech Interesting UTube vids Triumph 5
Rob Glasgow Interesting Art Work Austin Healey 2
JPSmit Interesting tools as gifts Restoration & Tools 1
Michael Oritt Interesting audio alternative Austin Healey 2
apbos Interesting dual cylinder Bugeye setup Spridgets 6
Rut Interesting non Spridget Spridgets 3
S Interesting book Spridgets 10
JPSmit Interesting Custom for sale Spridgets 13
JPSmit Tesla - but that's not what was interesting Other Cars 2
MikeAH100M Interesting Oil Cooler Austin Healey 6
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
M General TR Interesting Triumph 4
C TR4/4A Interesting Lucas lighting issue??? Triumph 5
Geo Hahn TR6 Interesting TR6 on OC Craigslist Triumph 12
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
JPSmit Cruise Night tonight - not pretty but interesting Other Cars 8
JPSmit What was on the trailers was most interesting today Spotted 2
JPSmit Interesting what people modify Other Cars 3
AN5Sprite Interesting Midget For Sale. Spridgets 5
Healey Nut Interesting find Austin Healey 1
W Interesting wheel...especially interesting photos Spridgets 3
CLEAH Interesting Early Sprite Spridgets 6
pkmh Interesting little jack stand discovery, "Drednaut" Austin Healey 0
HealeyRick Interesting 100 Coupe Austin Healey 13
B Interesting car on Craigslist [Sabra] Other British Cars 9
60TR3A TR2/3/3A Interesting TR3 on eBay Triumph 5
SilentUnicorn Interesting Ad British Motorbikes 1
