TR3driver
Great Pumpkin - R.I.P
My mistake, sorry!LastDeadLast said:It's there from 1972 and up.
TheSearcherMan said:I didn't mean "bucket". You could run a 1/4" hose thru the small gas can neck, and keep the fumes down. A bucket will have alot of fumes. And, you may want to do this outside, with a fire extinguisher.
fogdot said:Exactly where in the system is the pressure gauge tapped in? It seems that the problem would be between the pump and the point where the pressure is taken.
I had a similar problem in another vehicle with gravity feed fuel. I disconnected the fuel line at the tank,and put a rag over the end of the line. I "reverse flushed" the line with air pressure. When I blew out the line, the rag captured enough trash to restrict the fuel. Nothing major, just 50 years accumulation of small pieces of trash.
Brosky said:Yes, I think that he did, but I don't know if he ever solved it, so that's why I asked about him.
angelfj said:"Potato in exhaust pipe was the culprit the last time"
It's important to use the proper potato! :smirk:
</span>
