eejay56 said:Hey Don,
P.S are you going to the Portland ABFM this year?
DNK said:the next week have to fly to Savannah to take the daughter to college.
poolboy said:I've seen it done by just going from point A to point B with a heater hose, Don.
TOC said:Carb Icing. That's why V-8's had the exhaust ports that ran up under the carb, and a heat riser valve on one manifold. Air velocity, chill factor, you'll end up with a block of ice that can hold your throttles open, even kill the engine (or worse if the ice breaks loose and actually enters the combustion chamber). Until you move to a more temperate clime, leave it connected
DNK said:Has anyone ever bypassed the water pipe that goes thru the manifold?
Not used it at all?
/quote]
Just wondering why you would want to change this. Surely the engineers had a purpose for routing the coolant in this manner!
T
Brosky said:I would use it. It hurts nothing and it does get cold in your area of the country.
vivdownunder said:Not good arriving at a small country town and the car keeps going at 60mph.Viv
I've never tried it but the logic behind heating the fuel mixture escapes me. A colder eg: denser fuel mixture should lead to higher compression and more efficient combustion. That's why drag racers use a cool can in the fuel system.
