intake manifold to carb studs
Lin
Hi folks,
What kind of thread treatment do I put on the course threads of the studs that go into the aluminum intake manifold for the carbs?
Thanks,
Lin
1960 BT7 in restoration
1959 Bugeye
Assuming that the manifold threads are clean, and the stud is new, none is probably required. If the stud is not plated, then I would put some anti-sieze compound on the stud. As I'm assembling my BJ8, anti-sieze goes on almost all threaded connections, even if nuts and bolts are new. The anti-sieze will mess up some torque values, I understand, so be careful there, but the application you're talking about is not a high torque situation. The only real reason to use any compound there is to ease removal, but that's an unlikely problem in the manifold. Especially since I'm sure your Healey will be treated with utmost care during its second life.
Hi Lin, I would put a good antisieze compound on the engine side of the thread. What this will allow you to do in the future is remove a single carb off the car without the hassle of dealing with both. The method I use is to loosen the attaching nuts then with a very "small" pair of channel lock pliers placed under the carb flange, unscrew the studs. That carb can then be removed independent of the other.--Fwiw--Keoke
keoke, a good very good "antiseez" agent is "milk of magnesea" you know the stuff you take when your tummys actin up,used it on cars, and even hot sections of tubine engines,works like a charm, hay some guys use "doggy collars" dont they? /ubbthreads/images/graemlins/devilgrin.gif
[ QUOTE ]
[/ QUOTE ]
No wonder this guy can't get his Healey outta da garage.---Keoke- /ubbthreads/images/graemlins/grin.gif
[ QUOTE ]
keoke,that stuffs been used since its invention as "anti seez" at least mine dont belch! /ubbthreads/images/graemlins/grin.gif
[/ QUOTE ]
Thats just what I been trying to tell these folks; they spose to "Belch" soon as you hit the starter an yours won't do it.---Keoke- /ubbthreads/images/graemlins/nonod.gif- /ubbthreads/images/graemlins/grin.gif
keoke,no,-no belch, but o.k. it might "fort" a bit! remember im a still waitin on the # 2 carb. choke cable! /ubbthreads/images/graemlins/jester.gif
[ QUOTE ]
[/ QUOTE ]
I shure do not know why :U: be waitin on one of them things, when all "U" need is a bicycle brake cable an "U" be good to go.--Keoke-AZ- /ubbthreads/images/graemlins/cowboy.gif
keoke, when i rebuilt the carbs both choke cable ends were frayed i was able to buy a new #1 carb cable and installed it i salvaged and used the old #1 since its the longer of the two and install it on the shorter run on #2 carb,the rebuild made an "astounding" difference as i expected it would,thanks go to joe curto for having all the right parts unlike "the guy down the road" and yes my son has one of them carbon fiber racing bikes id been eyeballing the brake cables for a couple a days he must have got wise to the formulating plot cuz the bike suddenly dissapeared! /ubbthreads/images/graemlins/grin.gif
/ubbthreads/images/graemlins/savewave.gif
SHG !, init a cotten picken shame when your own Son cain.t trust you, or did you mean you hid the Bike after "U" stole the cables Anthony?----Keoke- /ubbthreads/images/graemlins/devilgrin.gif
