TR2/3/3A Instrument troubleshoot
Crankshaft
My fuel and amp gauges stopped working at the same time. When something like that happens I first think of ground issues. Does that sound reasonable, and if so, where would be a logical place to begin to search?
TR3driver
Great Pumpkin - R.I.P
Doesn't make sense to me; the ammeter does not need a ground at all. Sounds like you have two unrelated problems (which can happen).
Ground is definitely an issue with the fuel gauge, though. I always suggest adding a ground wire from under one of the mounting nuts, over to the ground tie point on the back of the panel. Or, if you don't have the panel out, you could run it to some other good ground. The factory relied on the ground through the mounting clamps, which is by no means reliable.
Adding a ground wire to the fuel sender seems prudent to me as well. Mine runs down to one of the tank mounting bolts inside the trunk.
Crankshaft
Crankshaft
Thanks Randall, I'll definately try the sending unit. I had a ground wire in the mounting nut but might pull the dash to have a look back there as well.
sp53
Randall has bailed me out all the time with electrical stuff, and I am far of being an expert, so I will try and make a wild theory here.
When I think of the amp gauge, I think of how the gauge is in line of a hot wire and not across 2 wires like a volt meter. Which I guess a fuel gauge basically is--- a volt meter with hot and ground with resistance in the center. Having said all that, the 2 gauges are next to each other so maybe something happened, but yes not a direct correlation. If the glove box is out of your car or you do not have a heater, looking around the back of the dash is easier and that is where I would start. I would unhook one of the battery cables or loosen it, so I can unhook and re-hook, but start with it unhooked and look and see if something fell.
Crankshaft
Crankshaft
Were I not such a goof and accustomed to making blunders like this I would not even tell what was found. Had wires switched on fuel gauge from when I cleaned it last year. Even had them labeled but still managed to cross them. Thanks again Randall and sp53 for the help and apologies for bothering you with such a trick. Still working on amp meter. :redface-new:
sp53
Glad you found part of it. I would check for lose connections on the amp meter. It basically sits in the wirer of a hot lead and measures current as the current passes through it. I am not sure if an open or broke ammeter will shut the car down or not, but I think the charging system and the ignition light do not work if the ammeter is out because there was a post demonstrating that when a voltage regulator goes out that effects major parts of the whole system and the ammeter is right in line with the voltage regulator. So does your car start and the ignition light go out? Randall would know.
TR3driver
A bad connection to the ammeter, or open circuit inside it will indeed shut down almost everything including the ignition and starter button on the dash. The horns would still work, and the starter from the rubber button on the starter solenoid; but not anything else.
Only way to get the engine to run would be to "hot wire" the coil to the battery, and use the rubber button to crank it. But the ignition light might go out, if it gets power back from the hot wire to the coil.
It's not impossible for the ammeter itself to fail, but I've never seen one that would not work and still pass current to the rest of the car. So more likely a wiring problem IMO, especially since you've been working on the wiring.
One test would be to remove one of the wires at the ammeter (or at the other end) and see if anything still gets power from the battery.
Power from the battery is tapped by the brown wire at the starter solenoid, brown wire runs from there over to the fuse block where it powers the horn fuse and then runs to the ammeter. The other side of the ammeter should be a brown/white wire, which runs back out to terminal "A" on the control box (regulator).
Crankshaft
Crankshaft
As I removed, tested wire continuity, cleaned and replaced connectors the problem has been fixed. As a bonus I became much more familiar with wiring diagrams. At my age, I don't buy green bananas anymore but it's never too late to learn and try new things. Thank you both for the input.
edkap2002 TR6 Brighter instrument lights? Triumph 0
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
LAW75 Instrument Panel Lights Austin Healey 9
bighealeysource LED Instrument Lights Austin Healey 12
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
steveg Improved Instrument Lighting Austin Healey 2
Crankshaft TR2/3/3A Instrument panel cleanup Triumph 4
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
Gerald_Gordon TR4/4A TR4 instrument panel Triumph 7
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
S Instrument Panel Lights Spridgets 6
R TR4/4A Question about cleaning instrument faces Triumph 8
MGTF1250Dave T-Series TF Dash Instrument Panel Studs Size MG 2
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
CJD General TR Instrument Faces Triumph 111
Jim_Gruber Instrument Bezels for BE Instruments Spridgets 4
Gerry M TR6 Instrument panel light bulbs Triumph 1
L Instrument O rings and switch plate mounting Austin Healey 4
Nelson Instrument bulb replacements Spridgets 14
T current instrument rebuilding info from Nissonger Austin Healey 3
M TR4/4A tr4a instrument knob removal? Triumph 9
T XKE Series 2 Instrument Panel Jaguar 2
M Instrument lights, etc. Triumph 8
AH100M 100/4 Instrument panel silver paint Austin Healey 5
Tinkerman TR2/3/3A TR3A Dash and Instrument Cluster Installation Triumph 11
Tinkerman Bench Testing a Wired Instrument Cluster Triumph 7
ekamm TR2/3/3A removing tr3 instrument panel Triumph 15
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
Tinkerman Instrument Cluster Assembled, YEA ! Triumph 22
Tinkerman TR2/3/3A Instrument Cluster TR 3A Triumph 14
J TR2/3/3A TR3A instrument restoration Triumph 11
Nelson New instrument lamps Spridgets 10
HerronScott TR4/4A Smith's Instrument List for TR2-4A? Triumph 1
Tinkerman TR2/3/3A Instrument Panel TR3, Question about back. Triumph 29
T MGB MGB Instrument Lighting MG 7
B instrument led lamps Austin Healey 12
prb51 TR2/3/3A TR3 instrument lights Triumph 4
J Removing Healy wood instrument panel BJ7 Austin Healey 3
HEALEYJAG BN1-instrument light wiring harness Austin Healey 0
B What is the color inside the instrument. Austin Healey 2
10musketeer Cleaning Instrument Faces Restoration & Tools 1
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
jjbunn Instrument Dial Rims Triumph 12
Tinkerman TR2/3/3A TR3 Instrument Glass Triumph 5
6 Dash Instrument Conversion: BJ8 > BT7 Austin Healey 3
PAUL161 Instrument Bulbs MG 12
S Spitfire 74 Spitfire instrument panel, Walnut or Teak? Triumph 5
M 87 XJ6 Instrument Problem Jaguar 3
2wrench TR6 Instrument & other bulbs for TR6 Triumph 5
