mbrooks
I'm just about to install a rebuilt trafficator/horn push assembly on my BN2. Since it didn't have one when I bought the car, I have a few questions.
1. It is a non-adjustable column car with the full-length stator tube, which is still installed. I need to take it out since PO has sawn off the three screws at the top. I need to remove the stator tube to take out the remains of the screws. Will the olive at the bottom simply slide off when I undo the nut? Can I re-use the olive?
2. How does the cancelling ring fit? Does it go under the steering wheel nut? What stops it from rotating relative to the steering wheel?
3. Anything else I need to be aware of? Any consumables I need to get? /ubbthreads/images/graemlins/confused.gif
Thanks in advance for any help.
Mike
Mike
Hi Guest!
