kbash
I'm installing the new water pump today and tomorrow. I had a couple <u>(of)</u> issues in <u>the</u> parts area<u>. W</u>hen I got the pump on there was an extra hole that I had to plug, so I go<u>t</u> that done. The only bad thing is I need a long screw.
Is it safe to use the anti freeze, it<u>'</u>s in a clean bucket and when I drained the car I drained it through a sieve to make sure there wasn’t anything in the fluid system, lucky from me there was not.
I put sealant on the gasket, <u>b</u>ut I can<u>'t</u> use it tonight. C[/i]</u>an I use it tomorrow or will I need to order a new gasket from the store?
I was wondering <u>also</u>, if<u>,</u> including the electric fans<u>,</u> if it would matter or help if I put the stock pulley and fan on the end of the pump to keep the engine keep even cooler<u>. O</u>r is that a bad idea, or pointless?
Wish me luck going to get the right bolt in the morning a<u>n</u>d have the new pulley in before I leave for church <u>and</u> then work.
Cheers,
Keenan Bash
/ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/england.gif
Cheers,
Keenan Bash
