[ QUOTE ]
Dave,
A Christmas tree would be too good for them.. /ubbthreads/images/graemlins/hammer.gif
BTW re my previous post.. were the cracked 'towers' on the coil the likely cause of the problem???
[/ QUOTE ]
Hi Derek,
Not sure what to think about the problems. They are seemingly not related to any one thing.
Points can make a small mechanical noise as the cam/rubbing block open & close them. You can hear it when spinning a distributor on an old fashioned distributor machine. This noise is so slight that you would likely not hear it with the cap on & the engine running. A rubbing block that is not lubed makes the noise a bit louder.
Points can also make a noise if there is a large arc across them. This would normally be caused by a failed condenser or one that is not connected or one that is seriously mismatched to the coil, which in this case is not likely. Crank the engine over with the cap removed & see how much the points are arcing. It should be minimal. Don't know how to describe minimal.
The previous arcing at #6 could be caused by either a very wide plug gap or bad insulation on the wires.
The cracks in the coil top may or may not be causing a problem. Obviously they were not the whole problem, since you switched coils back & still have a noise. It depends if the cracks are near or into the center tower. It's pretty hard to distinguish the sound between mechanical clicking & electric spark clicking. If it matters, the Pertronix coils are an order of magnitude higher quality than the "Christmas tree" coil that you have.
As has been mentioned, arcing inside the distributor cap due to a bad cap or rotor can make a similar noise, but it would normally cause poor running. The previous suggestion of viewing in the dark while running is a good one to check plug wires & cap exterior.
In summary, you could lube the distributor cam (special lube used very sparingly), replace plug wires, cap, rotor, condenser, plugs, & points, in that order, & maybe eliminate the problem. Wide plug gaps will increase the problems, so start with .025" gaps.
After getting things under control, patch the coil with JB weld as Keoke mentioned, & give it another try.
The 'super coil" would make insulation breakdown anywhere in the HV ignition circuit more likely. It would also increase point arcing somewhat due to it's increased coil primary current. If everything else is perfect, the new coil should work without problems except for shorter point life.
Sorry I'm not more help, the list of symptoms just don't fit any single cause that I can identify.
