Maybe I'm missing something really obvious here. But, at the risk of embarrassment, I will ask anyway.
The BN-4 came with six or eight used, worn out rear springs; no two matched in condition and arc. So I ordered new ones. My first experience with 100-6 springs came back when I was twenty and a spring broke. As I recall it, while lying on my back in the parking lot, a big hammer and a couple of wrenches sufficed to install a replacement spring from a Healey we found in the junkyard.
Now to yesterday. I first laid the rear axle across the top of the frame members, resting the axle on the quarter inch or so thick rubber covered rectangular rebound pads. Then I installed the springs, with the bolt at the front and the shackles at the rear. They appeared to be the right springs, as everything lined up at both ends.
It then became obvious that this was not going to be an easy job. There was nearly three inches of space between the mid point top of the leaf springs and the metal pads on the bottom of the axle. The new U bolts would not come close to reaching; about two inches short. A hydraulic jack placed under the mid-point of the spring did not help much as the rear of the car (light, since it is disassembled with no drive train or outer body) just rose up in the air.
Thinking that I had the wrong parts, I called the supplier. They confirmed that I had the right parts, and their tech guy had no helpful ideas. He had not heard of this problem before.
Finally, I made up a longer U bolt out of threaded rod and used that, with the hydraulic jack to hold the plate with four holes below the spring from tilting, and pulled the spring and axle together to the point where the proper length U bolts would reach. Then I replaced the temporary longer U bolt with the correct one. Then I did the same thing on the other side of the car.
This still does not seem correct to me. For one thing, the axle is sitting solidly on the frame/rebound pads, with considerable tension forcing the axle against the frame. It seems that it will take quite some weight to bring movement into the springs. Maybe once the drivetrain and body are installed, the springs will work as designed?? Another thing that concerns me has to with the safety of installing and removing springs with this much tension on them. One needs to treat these things with respect.
Has anyone else experienced this, and is this normal? If so, how did you install the springs? Could these springs be over-arched?
Thanks for any insights.
