So I'm back on days off and trying to get the floor pans into the car, now the questions is I know it sits /fits under the dog leg skin, I'm assuming the fit under the kick panel skin, I know it sits on to of the trans tunnel, but after that I'm not sure.
its a pre 60000 car with the slope, so does it fit under the wheel tub or on top of the 1/2 lip? Same as right at the firewall, does the fire wall sit on it or does the floor sit on the firewall 1/2 lip?
As I had no floors for copying purposes I'm not sure how to fit the floor at the moment, currently I've got to trim the front so it matches up with the firewall, and a little bit of trimming to do at the wheel tub, but after that I should be good for temporarily installing it while I keep up the repair/rust work. Still lots of rust to cut out and replace before I tackle the sill.
Thanks
Thanks
Hi Guest!
