Maybe I did something wrong when I made my TR3A door panels. If I first install the door latch pull cable and get it tight, I then can't get the door pocket over the cable. If I try to thread the pull cable through the door pocket and then bolt it into the door latch, I can't get the cable tight enough because when I lean the door panel out to reach the latch bolt, it pulls the cable out so it is not tight. Are there any tricks on how to do this? Thanks!
Regards,
Bob
Regards,
Bob
