Go_Dogs_Go
I am adding an alternator to my Sprite. The engine is a 1275.
The alternator has 2 large connectors and one small connector. My generator connected one heavy gauge wire (yellow and brown) with a large connector and also a smaller brown wire with a smaller connector. Both go to the relay (?)box.
This next apparently obvious question is because MOSS gave me a connector kit that explains there were 5 wires wired to the generator. Not in my case as I explained above. In my situation is it really as simple as conecting the large to the large and the small to the small?
Should something else be wired to the alternator?
Thanks. Happy 4th to you.
