I would use a slightly modified method of what Kurt is suggesting.
Turn the engine until you are somewhere between 5 and 8 BTDC for #1 on its firing stroke.
Fit the new dizzy and connect its low- and high-tension wires.
Turn the dizzy body so the rotor is pointing roughly at the cap terminal for plug wire #1.
Turn the ignition key to the run position.
Rotate the dizzy body slowly counterclockwise until you are sure the points are closed.
Now VERY SLOWLY rotate the distributor body clockwise until you see the points open as indicated by a tiny spark.
Lock the distributor down a bit, refit the cap and rotor, and start the engine. Now do your dynamic timing.
In the boot I carry a length of wire soldered to a turn signal bulb. I use that setup as a test lamp when/if needed and can cut the wire off the lamp to make repairs on the road. You can also use it as a static timing light so you don't have to watch for the spark across the points. To do that, modify the procedure above. Stuff the stripped wire on the test lamp into a connector on coil (-)... the distributor side terminal of the coil. With the ignition in the run position hold the test lamp against ground. As above, turn the dizzy counterclockwise until the lamp is OUT/OFF and then a few more degrees counterclockwise. Then SLOWLY turn it back clockwise until the test lamp just turns on. Finish as above by fitting the cap and rotor and carrying out the dynamic timing.
