I've torqued the castle nuts down, but the hole for the cotter pin is hidden behind the peaks of the nut. Should I continue to tighten until the hole is accessible through one of the notches?
What's the application. If you're going onto a fixed large retainer I've been taught to use a thin steel washer under the castle nut 1st, 2nd slightly overtorque, 3d lossen to the closest slot.
Modern upgrade is to replace the castle with a nylock aircarft quality nut.
Shimming is indeed the proper answer but if you are talking about the top of the king-pin then backing it off to the next space has worked for me.
Bill
Application is indeed the front suspension. I think there's one on the top of the king pin, and another right next to it for the upper fulcrum. Would nyloc nuts be a little weak here?
I will try shimming with a washer first. Does shimming with washers also work if the cotter pin is too high and not engaging in the castellated portion of the nut?
